Hello all!
More History on this car is here. I'll be updating the list in there as well.
http://www.toyotanation.com/forum/1...solara-1999-2003/1450442-kingdom934-s-1998-camry-le-v6-anniversary-edition.html
When I got the car, motor mounts were shot. Shifts were very harsh...still is even after...another thread on that.
The car did vibrate quite a lot in park and when in gear especially. It was causing some panels to vibrate and rattle. After the mounts were replaced, everything seems to had smooth out as it should...except for the shifting issue noted below.
http://www.toyotanation.com/forum/1...n-solara-1999-2003/1618650-transmission-kick-down-cable-shifting-too-harsh.html
Anyhow, the mounts had to get replaced. I bought all the parts from our awesome Roman from Toyota of Cool Springs.
NOTE: This guide should be fairly applicable to many of the 1MZ family, including the Sienna, ES300, Avalon, and Solara. Of course, use common sense when attempting any kind of repair work.
http://www.toyotanation.com/forum/506-toyota-cool-springs/
It all started on this day...
The part list ran like this for a Toyota Camry 1998 LE V6 Motor Mounts.
Rear Mount w/ Housing (do NOT get JUST the bushing - Yes it is cheaper, but you need to press that ***** in!)
12380-0a031
https://parts.toyotaofcoolsprings.com/oem-parts/toyota-rear-mount-123800a031
Transmission Mount :
12372-0A020
https://parts.toyotaofcoolsprings.com/oem-parts/toyota-side-mount-123720a020
Front Mount :
12361-20040
https://parts.toyotaofcoolsprings.com/oem-parts/toyota-front-mount-1236120040
Dog Bone (Torque Strut) :
12363-20020
https://parts.toyotaofcoolsprings.com/oem-parts/toyota-torque-rod-1236320020
Transmission Shift Shock Strut :
12307-20021
https://parts.toyotaofcoolsprings.com/oem-parts/toyota-vibration-damper-1230720021
Anyhow, time to get started.
Here's that 2.5 year old box...been in my trunk.
I finally... (been using this phase a lot) got time to do my motor mounts one afternoon. I was bored and I knew I wanted to get rid of this box that was sitting in my trunk for over 2.5 Years.
12380-0a031
12372-0A020
Front Mount :
12361-20040
12363-20020
12307-20021
