So my new rims are shipping and I should receive them either today or tomorrow. Some people were telling me I need a torque wrench? Is that really necessary and how do I use it?
Good advice, I cracked a wheel lock because I did'nt have a torque wrench.lammydi said:Yes, you should use the torque wrench. The purpose of the torque wrench is to have the correct torque. You don't want too much torque which could damage/warp your rotor and damage your lug nuts nor not enough torque which can cause too loose lug nuts which is really bad because you might end up having your tires came off your car while driving. I think it is this fear that most people think the more torque they applied the better.
The correct torque setting for our 07 Camry is 77 lbs. You can buy them at any autoparts stores like Autozone, Kragen, etc...and ask them to show you how to use it.
Good luck.
What a Joke!!!geoff5093 said:If you're just replacing the rims you dont need one. All I used was the tire jack and lug nut wrench that were in my trunk. Just make sure to re-tighten the lugs after you drive a bit to make sure they are secure.
When you go to a mechanic, they use the air tools. Are those similar to a torque wrench or are they just like a regular wrench? (Meaning do they torque it to 77lbs, or just tighten is as much as they can?)njerald said:What a Joke!!!
You have a LOT to learn.geoff5093 said:When you go to a mechanic, they use the air tools. Are those similar to a torque wrench or are they just like a regular wrench? (Meaning do they torque it to 77lbs, or just tighten is as much as they can?)
My main worry from overtightening the lug nuts would be warping my brake rotors.geoff5093 said:Since where on the topic and I obviously didnt know you should use a torque wrench for the lugs, would overtightening them cause the car to vibrate a bit when going atound 75mph?
If you are bending or stretching the wheel or the rotor a bit, it moves the metal around and therefore it becomes slightly out of round and slightly out of balance. Out of round means it will vibrate. Evenly torque the bolts alternately until you get to about 50 foot pounds and then do it all again to 77 foot pounds.geoff5093 said:Since where on the topic and I obviously didnt know you should use a torque wrench for the lugs, would overtightening them cause the car to vibrate a bit when going atound 75mph?
I am the one said 77 ft/lb for Gen 6. I got this from a reliable source on this forum, kyle@tirerack.ScrooYoo said:so the correct setting for Gen 6 is 77fp. Anyone know the correct setting for Gen 5?
