"pull OBD I trouble codes with a paper clip"
"I don't understand what you are suggesting"
Here is a link to a thread in which I go through the Diagnostic Link Codes (sometimes referred to as "OBDI"), see post #244:
I didn't start out intending to own a Camry for this long. But when I bought this 1993 Camry SE V6 (3VZ-FE) 5MT, in October of 1992, it seemed to be good enough for my needs. It handled like a pig when new, but finally I found a shop which specialized in race cars and they set up the alignment...
www.toyotanation.com
The way to get your check engine light to blink out an error code is to connect terminals TE1 and E1 together. Most use a paperclip because it is easy and everyone has one. Note that you can use just about anything to connect the two terminals together, in my link above I showed how a made a very nice one out of a pair of Toyota wire harness repair parts as a replica of the SST the manual talks about.
Attached is a .pdf of that portion of the shop manual which lists the DLC codes, and has more details how to get them from the blinking "check engine" light, when you connect TE1 and E1 together, for your reference:
