Thanks. I dropped the subframe and installed all new suspension too. The old rear main didnt look too bad.
Dont think it has a vacuum hose on the a140e for my year 5sfe. It does have what I think is throttle cable which is adjusted to about .06 rubber stopper extension. Im currently replacing vacuum hoses, doing the evap hoses next.
List of new parts
Has new spark plugs, spark plug wires, distributor, distributor cap and rotor, alternator pigtail (lowered cold idle rpm from 1500 to 1250),upstream o2 sensor, egr vsv, egr modulator, egr valve, egr vacuum hoses, pcv valve, 170 thermostat, oil pressure sending unit, fuses, tires, front and rear suspension, front brakes, front and rear wheel bearings, cv axles, rack and pinion, inner and outer tie rods, ecm
Everything was defective thats why it was replaced.
A Used igniter was swapped on, maybe its defective
Alternator sometimes only charges 13.8 on days and 14.2 on other days, also have a .115 voltage drop on alternator positive cable. The battery voltage on the next day is 12.4
The new cv axles have tone rings whereas the stock axles did not, not sure if they are rubbing or not.
Car barely pulls to the right both the same amount with brakes applied and without brakes applied, it has new suspension , alignment, brake pads, brake calipers, brake rotors, wheel bearings, not sure if rotors are catching the backing plate or calipers sticking, or needs a master cylinder.
There is some hissing behind steering wheel that gets worse when turning steering wheel to the left not sure if its the new rack and pinion or brake booster.
as far as the new fuel injector orings, I only replaced two orings not all four , and the new orings are considerably thinner than the old ones, not sure if thats causing a fuel leak or not, its running 14 %rich long term
When the car engine is cold, it starts up fast but when the engine is warm , it turns over longer before it starts
My vacuum reading slowly fluctuates between 20 and 20.5 inhg. When the fans come on the vacuum reading quickly fluctuates so fast you cant read it between 18 and 20.5 hg
