Just wanted to chime in if you guys didn't know about this remote start/keyless entry install available for the 2017-18 corolla. The one I will be talking about is for the standard non push to start models with the H key. (H engraved in your key). They have push to start stuff too but not what I was looking into to.
I installed this today in my 2017 LE and it literally took 45 minutes and YOU DONT HAVE TO CUT A WIRE!!! It's plug and play basically and the car doesn't die when you open door like factory ones.
Remove the two screws behind steering wheel by turning wheel. Squeeze dash column cover and pop it off.
Not gonna get technical below... Fortin website has a PDF with everything you need for locations and such... Just showing you how easy this is...
Unhook a harness at ignition and hook up this harness.
Unhook a harness under fuse box and hook up this harness
Connect harness to OBD2 port. (It leaves a pigtail so you can hook up a scanner later)
Loosen a bolt somewhere and land the ground wire and retighten.
Follow the programming instructions. (Takes 1 minutes tops).
You can opt to use factory keyfob to start but since the range sucks so bad I bought the add on 2 way remote that works from like 2500 ft away. It has one plug into remote start box and a 30 second programming sequence for the remotes. If you choose to use factory keyfob to remote start you have to hook up one more thing for tpms sensor.
Since my car is an automatic you need to cut a jumper on evo-one but eBay seller had even done that for me.
Done!!! 45 min tops! I wasn't reading programming instructions well enough (cause in my head I'm smarter than them instructions...lol). Or otherwise this should be a 30 min install.
I ordered everything from eBay. Seller is a car installer so he flashes everything for you so it's ready to install.
Seller was **Redacted**
He combined shipping for me so total cost was 282$ for the unit, quick harnesses and rf remotes.
What I ordered:
Fortin EVO-ONE. (All in one remote starter)
Fortin RF642W. (Rf 2 way remotes)
THAR-ONE-TOY8. (Quick harness for Toyota Corolla)
I have installed multiple remote starts from scratch but this was so simple anyone can do it.
Any questions I don't mind helping ya out. It was so easy!!!
What I ordered:
