Hello fellow corolla owners, I have a serious question needing a serious answer.
I replaced the sock on the fuel pump assembly yesterday, and the car started up fine immediately afterwards. Thinking I was in the clear, I shut it off, put everything away, and went about my business. I woke up this morning and was heading out, but the car would crank and crank, but no start. I tested the coils, battery, battery cable connections, grounds, etc. to no avail.
Since it's so easy to get to the fuel pump connector, I figured it was worth a shot. I turned the key to ON, grabbed my voltmeter, and probed the blue/black wire for power at the pump connector: no dice. Following the wire up to the Circuit Opening Relay under the dashboard, I unplugged it and tested it, and it works fine. However, no power to the relay when key ON. Moving under the hood, I tried the EFI relay; it works fine, and is getting power with key ON. What gives?
Is it possible that there's a break in the circuit in the <24" of wire between the underhood fuse panel and the underdashboard panel? I really don't want to tear that dash apart looking for it. Could it be as simple as "power doesn't get to the Circuit Opening Relay with key ON, but rather only with key START"? I'm incredibly frustrated and need to get to work in the morning. Any suggestions? Please address the relay questions before any advice on actually diagnosing the crank/no start condition, there seems to be an acute lack of information on this everywhere I've looked.
