EFI Relay Mystery
15K views 9 replies 7 participants last post by  Fazz
Okay, here's today's puzzle...
94 Camry 2.2L (391,000 mi!!) runs like new until a few days ago.
Tried to start it up: strong cranking but wouldn't start.
Pulled the EFI relay and put it back in. Started right up.
Ran beautifully for two days without a hitch.
Ran an errand and on my way home died in the middle of the road.
Had it towed home. At home it cranks but still wouldn't start.
Pulled the EFI relay and put it back in and it started right up. Figured it was a bad relay since it was the only thing I touched. Replaced it with a new one.
Everything seemed fine until today...parked for about an hour came out, again it cranked but wouldn't start. You guessed it, pulled the relay and put it back in and fired right up.
Anybody have any ideas? Keep in mind that once it fires up the engine runs smoothly.
Could be the ECU's going bad? When it won't start, does the CHECK ENGINE light come on when you put the ignition switch in the ON position? If not, that indicates the ECU is not powered up.
The EFI Relay supplies power to the Circuit Opening Relay, which in turn powers the fuel pump. The next time it fails to start, try removing the COR, cleaning the contacts with electrical contact cleaner. ... Problem could also be something wrong with the fuel pump. They seem to fail occasionally.
Thanks for all of the suggestions and comments! Next time it fails to start I will pay closer attention to the check engine light, though I'm pretty sure it does come on when the key is in the "on" position.
Unfortunately, I can't create the problem on-demand to test a lot of things.
I like 71corolla's idea that there is something wrong with terminals where the relay plugs in.
I can't explain why taking out the relay and putting it back in would have any effect on the ECU, the COR or the fuel pump. And as you see from my experience this always gets the car to start. I admit I'm not very knowledgeable about electrical systems but I assume once the car is shut off and the relay opens it is no longer energized and can not affect any other component when removed and then put back in.
try using starter fluid
Buy a can of starter fluid ... ether ... The next time it doesn't start, remove the air filter and put a short burst in the air intake. If the no-start condition is related to lack of fuel, the ether will allow the engine to run for a few seconds. If that is the case, then it is the fuel pump, or one of those relays that is the problem. ... Seem to recall that fuel pumps can be intermittent, or weak when they are failing.
It would be helpful to know the year of your Corolla.
