hi ive been having a problem with my afm,
when the afm is plugged in the car will run for 15 seconds then cut out, it does this every time. the afm was tested and the readings were all correct but decided to replace it any way. with the new afm the car behaves exactly the same. after further testing i have found the car will run if i disconnect 1 wire from the afm. (its grey with a black line and small brown bands. its the second wire in looking from the front of the car) but it runs n limp mode, connect it back and it dies after 15 seconds again.
does anyone know what this fault is, whats broken or how to fix it?
the manual suggests a faulty afm, a short in the circuit of faulty ecu, ive tested 2 afm's checked the wiring for shorts.
thanks in advance for any help
pete
pete
