Hello everyone,
I have a 2013 Camry LE, and noticed oil stains on the left side of the engine, apparently from a hex socket screw/bolt. The hex head size is about 12mm (I am not 100% sure about the size). I was wondering if I can simply tighten it, or there is a seal to be replaced. I can't find any information of this screw online. Did anyone have the same issue before?
By the way, I will replace the engine valve gasket just to rule out its involvement.
Thank you,
Nick
Thank you,
Nick
