Excessive Battery Corrosion?
26K views 10 replies 9 participants last post by  bubbah16
I took my 2012 Corolla S (Around 29,500 miles) into the dealer for the 30k service last Monday. They noted on the inspection report that there was excessive corrosion on the battery terminals and they needed to be cleaned. I finally had a chance to go out this morning and clean them off and this is what I found:
Does this seem like a lot for the age of the car? On my old Volkswagen GTI I didn't have a similar issue until it had about 70-80k miles on it. I'm going to clean it off and put a few of those anti-corrosive washers on it but I'm concerned this might be indicative of a larger issue that needs to be addressed before the car is out of warranty in about four months.
...lead/acid batteries do that.
quick search result purdy much explains why...
https://answers.yahoo.com/question/index?qid=1006020306083
I'd suspect your battery could be leaking...
or someone spilled electrolyte on the terminals.
how to eliminate that issue !?
^ besides the little tricks that can help when using a lead/acid battery.
Get a gel cell battery and terminal corrosion/build up will no more.
and there are no tricks required.
My Optima YT looks and functions as good as it did
15 years ago.
And I've never had to do any terminal maintenance, ever.
Thanks for the responses. I got the little felt rings last week and put them on after cleaning it off thoroughly. I talked to the service writer earlier in the week and he said it was fairly common even at lower mileage from what he's seen. I guess between my old GTI and my wife's old Corolla (that didn't develop it until much later as well) I just wasn't expecting it this soon. But I'll check it every couple months from now on.
Thanks. I've been keeping an eye on it. I don't really buy the service writer's explanation. My wife's RAV4 is at 20k and is still clean as new. I've got one more service prior to the expiration of warranty in July and plan to push the issue with them then to replace it.
Your battery's positive terminal is not properly sealed in the casing, and some electrolyte is leaking... When electrically charged, the copper clamps react with sulphuric acid to produce copper sulphate (CuSO4), along with water and sulphur dioxide gas. Anhydrous copper sulphate changes to blue colour when water is added to it. The bluish substance which you see around corroded copper terminals or copper clamps is hydrated copper sulphate.
You just need a good new battery.
http://www.interstatebatteries.com/...utomotive-truck/mtp-35-toyota-corolla-2012-standard-battery-oem-cca-360-l4-1-8l
http://www.sears.com/diehard-gold-automotive-battery-group-size-35-price/p-02851835000P
#9 ·
It has nothing to do with your car, or any car for that matter. It's only the battery that is causing this as some do it more because of a small leak. It's not really a huge deal as you can keep it clean & you will be fine. It only takes a few minutes every 6-12 months. When you get a new battery you can buy a gel cell battery like an Optima and never have those issues again.
you definitely want to keep it clean as much as you can if you stick with the same battery. you don't want the corrosion to affect the terminal cable because that's a PIA to replace.
or like others have mentioned you can drop in a fresh, new battery
#11 ·
Last time I had a severe corrosion problem on my battery post was due to a crack near one of it's post that was leaking fume and added corrosion sulfure dust near it's post.
Upon a real close inspection found the crack had spread almost to a half moon circle around the affected post.
I got rid of it and bought a really nice used one and problem was solved for good.
Maybe you should have a real closeup check around both of them, who knows.
