5K views 9 replies 7 participants last post by  MaximX
Hi,
Last night my Highlander XSE 2023's Traction control got turned off automatically. Then I was not able connect to Apple Car Play. It took me 15 minutes to get it work. Has anyone faced similar issue before? Felt like a bug in the software. If there any update for the firmware?
I am located in Canada.
Thank you.
There shouldn't be a connection between the function of the traction control system and the multimedia screen, so that in itself is odd unless it's a coincidence somehow.
The only thing that you can update firmware on is the multimedia system, and Toyota doesn't issue updates for that very often. Toyota separates all of its computerized functions in different physical modules. The dealer has to update anything other than the multimedia system, again assuming that Toyota issued some kind of update for that particular module.
Entune 3.0 (prior to model year 2023) over-the-air updates only update the "Apps" on the system (which isn't much).
You must do the USB update to truly upgrade the firmware and get bug fixes for the system.
Not sure if Toyota Audio Multimedia (TAM) on the 2023's will have full OTA updates or not.
That update fixed two pet peeves I had with the entertainment unit. First in CarPlay Google Maps navigation mode it wouldn’t show what Sirius CM station I was tuned to, that now works.
Then if I am parked and using my phone while plugged into CarPlay and there was some type of video in a tweet or Facebook post it would switch the audio source to the iPhone. It still does that, but now when I navigate away from the video file the entertainment unit puts audio source back to Sirius.
#9 ·
hey i also have the 2023 xse i was wondering if we could connect and share somethings about our cars i am in vancouver and it rains alot and when i park i get rain water under my hood on the plastic bottom cover i was wondering if this is normal it has been stressing me for sometime and that if your does something similer u notice , also in my car the wind noise is loud sometimes and it comes alot of it from the rear wheel wells
USB updates is the only way to go. Highlander last update 2023. Check here and upload:Home | Toyota Software
Toyota Audio Multimedia System Updates
The software portal is designed to provide Toyota Customers with updates for their vehicle's Audio Multimedia system. Please input your vehicle information above to check available updates. For vehicle's with eligible updates a compatible USB drive will be required for the software download. The compatible USB drive will be used to update the vehicle Audio Multimedia system.
The software available for download through this site is only intended for vehicles manufactured for use in the continental United States, Alaska and Hawaii.
