Forced Compass Calibration
5.8K views 16 replies 4 participants last post by  LazerBoi_64
Hello,
I have a 2015 Camry XSE with a stock electrochromatic mirror and built-in compass. I recently installed an Escort Max360 radar detector with a Blendmount to the mirror stem. Now I'm noticing that the compass is misbehaving. I've tried changing the magnetic declination in hopes it would trigger a compass recal, but no luck. I've even changed the declination to a zone at the opposite end of the continent and still no request for calibration. Does anybody know if there's a way to force a compass calibration? Thanks!
The Blendmount is aluminum so I wouldn't think it would affect the compass. It does have a half-dozen steel 4-40 screws holding it together, but I'm guessing the detector might be the bigger source of distortion. I'll pull the detector tonight when I get home to see what happens. Will also grab my orienteering compass from my backpack and see if it picks up any distortions around the detector. Thanks for the quick response!
Ok, problem turned out to be something more subtle. It was the magnet that's inside the radar detector! Escort put a strong magnet inside the detector's case to help keep the detector and their sticky-cup mount mated. As I was getting ready to replace the screws with stainless ones, my steel Chapman Tool snapped against the detector and I knew immediately what the problem was. When I slid the detector out of the mount, the compass error got worse, and when I moved it away from the mirror and closer to the windshield, the compass began reading correctly. Now I have to pop the cover on the detector and remove the magnet.
#9 ·
Wasn't aware of there being other compasses in the car or where they might be located. I would guess there is one in the pod on the roof where the satellite and GPS antennae are located, but the other, no idea. In any event, if they're beyond a sphere roughly 1' in diameter and centered on the detector, they shouldn't be affected. Since the detector is essentially suspended in space right below and slightly in front of the mirror, the mirror should be the only thing affected.
#17 ·
Ahhh...been dealing with fiber optics too long. MFD to me means mode field diameter.
Anyway, I haven't seen any unusual behavior during my drive this morning. Compass responded in a timely fashion with every turn I made and nothing else seemed wonky. Got the Thinkware wired in yesterday so now I guess it's time to enjoy the fruits of my labor! Thanks all! :)
