Well-I've done quite a bit of DIY work on the Camry the past few years, thanks again to everybody here! Things such as soldering the broken blade in the wiper motor to fix the wipers to work in park and intermittent, and the trunk wiring that was bending when opening and closing the lid is fixed, the clock/outside temp gauge is soldered and fixed etc. etc.
My question is this: all my front end parts are in good shape. The steering feels good and tight, there is no shimmying on the highways and so on. But the car pulls to the right, especially on high-crowned roads and the drivers side front tire is worn on the inside edge, while the passenger front is not wearing abnormally. All these guys do at an alignment shop is turn those tie rods in or out to adjust that toe spec. Seems to me if I were to loosen that locknut on the drivers side tie rod - turn the rod a bit - tighten the locknut - and drive the car to see if the steering straightened up - and if not - keep making minor adjustments to that drivers side tie rod until the steering feels like it should.
When I go around a right hand turn on the highway - the car tracks perfectly - but once the road straitens out - bleh - back to the steering cocked off to the left and the pull to the right is 'right' back. After seeing some DIY's on YouTube - I'd rather fix this seemingly minor problem myself than spend the money for an alignment.
