FS: Gen 5 Camry TSX HID Retrofit
5.3K views 25 replies 8 participants last post by  LE05
sold!
yea tl is a bi xenon therefore regular low beams and high beams in one
tsx is just for low beams
get them, good price, and the output is so much better then stock halogens
ive seen them in person, love the touch of the blacked out projector shield cover
#16 ·
ahh i see; i have 4300k HIDs in my stock housings (yea i kno) and i'm happy with them.... the beam is almost identical to stock halogen.... but a razor sharp cutoff sounds nice
also how the hell would i wire the bulbs and ballasts...... ive hooked up HID kits before but theyre simple plug and play
#17 ·
wait hids in stock halogens? hope you lower the aim on them otherwise the glare will blind ppl. i hate when ppl dont adjust their headlight after putting in hids sorry but it is a big issue. nothing really too wrong to put hids in halogens as long as you adjust for the glare.
you can ask le05 for how he wired them up or pm pawel062 (he does retrofits and knows alot and in nj)
you would need a plug and play kit to wire up the bulbs and ballast which basically uses one stock connect for your headlight to trigger a relay that would pull power on a separate wire directly from your battery to the ballasts. considering you are running hids you run the risk of burning out your stock wires for your headlight since hids/ballast require a huge draw on power to ignite the ballast. hence the plug n play kit which basically reruns wires to power to the ballast on wire that will handle the high load amps it needs on start up and your stock connect just triggers a replay
hope this helps clear things up
#18 ·
also where in nj are you located? im in the north, and i meet up with pawel062 every now then so you can meet us if you want n get more info or see his retro
what do you drive anyways?
by the way sorry to op for this clutter on this thread just trying to help
You have insufficient privileges to reply here.
