I have the same question. The T165/90D18 donut is the same diameter (within 0.1" on a tire calculator, which could be rounding error) as the P245/55/R19 main tires. But the full size is 3 inches wider.
The muffler is right beside and just a few few inches from the unshielded donut, so I don't see any more problem with the wider full size tire, other than a small reduction in ground clearance. However it won't stick down any more than the factory 4-way tow connector at back and little more than the drive motor just a bit forward (and I'd rather bottom first on the tire than the motor).
Anyone see a problem I don't with mounting a full size spare? The 2019 HiHy manual even shows an alternate tire rotation that includes rotating the spare with the two mains on one side.
