Ok, Figure I'd start a thread to help people either keep the mpg they have, or find a reason to WHY they get bad mpg.
This is from personal experience between freinds and I.
First off, for highway driving, the 3VZ-FE/1MZ-FE V6 should be able to tap 30mpg on the highway. The 5SFE I4 should be able to do over 30mph.
Already get decent mpg? These are way's to keep it up there.
1: Tires, MUST be properly inflated. Under inflated tires hurt your mpg more then you know. But over inflated will also ware the tire faster.
2: Roof racks and other attachable items. Just like under inflated tires, most things added to your car cause drag, tielding less mpg. If you have any roof rakes, bike rakes, etc attached to the car, that can be taken off off then not used, do so.
3: Driving style. A big part of mpg loss for city driving is your start and stop. When accelerating, do so slowly. Try not to go over 3k RPM's. Stopping, try to do it smothly and slowly. Also, putting a car in Neutral when stopped does not burn less gas as some think.
Currently getting horrible mpg? Here is some ways to help improve it.
1: Are there ANY check engine lights? If so, what are they? They can be read free at AutoZone and PepBoys in the US, and PartsSource in Canada. Often, a CEL indicates an issue that needs to be addressed. Item's such as O2 and AF sensors that go bad can greatly decrease your mpg. So get it checked out! I recommend replacing those sensors with OEM Toyota ones from the dealer. Yes, they cost more, but you get what you pay for. Also, thanks to Maim Menu for reminding me to add to Replace the air filter when dirty. It is often over looked.
2: Tune up. When did you last do one? Old Spark Plugs, Wires, Cap, and Rotor can decrease the mpg. It's normal maintmence to replace it. ***The 1MZ does not have wires, cap and rotor.***
3: Just a plain dirty engine? Try using Seafoam: http://www.seafoamsales.com/motorTuneUp.htm in your brake booster line. Some people here have reposted a MASSIVE (up to 50%) mpg increase. For the fuel injection system, pop a can of BG44K into the tank. BG44k, from what I have heard, is the top in it's class.
4: Big Rims. YES, they hurt your mpg in city driving. Some people on here have reported a significant decrease in mpg after instaling big rims. Just cause it looks good, does not make it good.
5: Junk in the trunk? If you have a lot of stuff in the car, it's un-needed weight. Remove it. The heavier the car, the more to pull.
6: Just GENERAL driving. Cruising speed on the highway is a big thing. My best mpg was 30.1 on my V6 over a 960 mile trip averaging about 75mph. It likely would have been 32 if I was going 65mph. Also, the more steady you keep the speed, the better. Try not to go up and down, but just even. Cruise Control is best to help achieve mpg if your on an open road. As I said, nice constant speed.
