Hatchback SE vs. XSE: what are the LESS subtle differences?
8.6K views 13 replies 7 participants last post by  AZTerraplane
Hi all, first post here. Age 52, long-time Toyota (& Lexus) owner & fan
New to forum and planning to buy a silver 2019-2022 hatchback with a Manual, as soon as I can find one that passes muster, but trying to sort out the less-obvious differences between the SE and XSE hatchback models. In a nutshell, the pickings are slim and I prefer the old-school analog gauges, lighter manual seats etc. I'll be putting on 17" wheels on whatever I buy (between 16" SE and 18" XSE), but I like the little things "here and there" that add to the XSE (talking exterior here). Main differences I'm aware of:
SE:
16" wheels
analog gauges
manual seats
smaller screen on earlier years
XSE: 18" wheels
LED/digital gauges
power seats
Different headlights?
Different Turn Signals?
Other exterior/body differences?
*Springs/suspension may be the same, but may not. Someone searched and found different part numbers for springs even though they may indeed be the same, just marked different for inventory. Does anyone know?
My main question: Aside from 18" wheels, what would someone need to do to make the exterior of an SE be identical to an XSE? I believe the XSE has chrome bezels/trim on the front bumper, possibly "LED turn signals" and at least some have fog/driving lights. I found a 2019 SE and may buy it and go junk yarding/ebaying for the XSE parts. On that note...are electrical bits like the fog/driving lights a plug & play upgrade? Any other items I may have missed? Basically I want the more simple SE...lighter seats, simple gauge cluster, but want to bring the exterior up to XSE level. I'd happily buy a clean XSE but right now all I can find are SE's in my area, so I'm looking to improvise.
Thanks all!
-Chris
#2 · (Edited)
Good morning Chris and welcome to the board!
Yes, I think you captured most of the differences in your post. Exterior wise, SE is missing fog lamps and front mask chrome pieces on the bumper cover. There are many kits out there to choose from for both fogs and trim pieces. Many XSEs came with an additional hatch wing.
If you search within this forum you will find a few fog light install threads:
Fogs and trim pieces can be found on AliExpress for le$$...
Other things are interior and chassis related, e.g. hood insulator, leather(ish) power seats, heated seats, mirrors and stg wheel (depending on location), larger media screen, JBL, digital combi meter, possibly suspension springs (this one is still out for debate), etc...
This post has been deleted
I just ordered an xse
First thing is diffuser and exhaust
Second is chrome trim goes bye bye
Aliexpress tho ?
Well, I too prefer XSE looks over SE and SE-Upgrade. We all have our tastes and likes ;)
And yes, I picked up some chrome pieces for my HB from AEx, fog LEDs and many other accessories...
I have it from the time I bought mine, but it does not show the trim pieces on the front bumper cover, etc.
Here is the brochure...
Reactions: AZTerraplane
I could be wrong about this, as my HB is an XSE (with the delightful 6MT), but I'm under the impression that the SE lacks the side mirror integrated turn signals. I think all other exterior cosmetic differences have already been noted... Just double-checked and I see that nobody mentioned the badge :p
Regarding the addition of fog lights, I just installed a set on a 23 RAV4. They are not plug and play. You'll have to install a wiring harness that will need to be run through the firewall to an interior button. You may not care about this but stock fog lights are controlled by a switch on the left column stick and feature a dash indicator light when they are on. But for the sake of outside appearance only, there are certainly options available.
#11 ·
Unless things have changed, the SE doesn't have the hood insulator pad standard from the factory (tacky, tacky Toyota), so the engine sounds more annoyingly like it's sitting in a hollow tin can.
