I wonder if anybody else has this problem. I can drive the truck all day long and it doesn't overheat. I'll check the radiators temp with a infrared temp gun and as long as it's running I get 165 degrees allowing 10 to 15 degrees for the radiator body should be about 180 degrees. Just right. The problem is when I shut it off even after a 30 or 40 minute drive I'll come back out to start it and the temp Guage is darn near in the red. I'm in Alaska the hottest it gets around here is 75. Is this normal for the 3.0. I've already paid to get head gasket replaced once don't want to do it again. 92 dlx with 3.0 245000 miles.
