I stripped the threads on my cylinder head when trying to install my camshaft bearing caps. I'm not quite sure how it happened, but trying to remedy the situation. In the process, I bought a helicoil kit (M6 x 1.0) for about $25, but I'm find that the helicoils are too short (~8mm) whereas my bolt would sit 15mm into the head.
I found a place online that actually sells 15mm length version of the helicoils, but in the process of researching I've read that some people prefer timesert over helicoils and that one has advantages over the other depending on the situation (not sure what those advantages are though).
I'd prefer to do the job right the first time around, and now that I'm making a purchase again, I figured I'd ask: Should I get timeserts rather than helicoils? When should one use one vs. the other?
