Hello, any info on a 2JZ-GTE Swap in an IS300?
26K views 10 replies 8 participants last post by  SoCal_VIP
Looking for some info on the swap, if anyone has any I'd greatly appreciate it. Thank you!
Greatwars said:
The problem with the swap isn't the power you can produce but with the tires to stick on the road ... I dont think lexus IS is capable to put much wider tires (something like 300s)...
You don't need a super fat setup unless you are looking to produce over 700rwhp. And for that matter, the IS can handle 300 series tires, you just need to shave and pull the fenders to make room.
#9 ·
correct me if im wrong, but arent the best "high hp" trannys sequential?....i too will be doing research on a 2JZ-GTE swap....NYLex has been talking me into buyin an SC300
i have lotsa plans for it too....dunno if i dare go over 500hp...but i aim for a min 400
the IS300 was my original car of choice for the 2JZ swap, but still has a high resale value, the SC300s with higher mileage is basically all i can afford if i wanna get serious in modding...and they look sexy as hell, and have a timeless body 92-00..generally the same shape with minimal body mods....
just my $.02
btw NYLexSC...even if you consider your car "slow" like you said in the other threads...youd still be able to walk away from my "fast" camry ANY day!, lmao
