Hi,
My 2004 Camry 3.3 V6 (3MZ-FE) has started to run a bit sluggish at highway speeds and sometimes in stop and go traffic.
This P0430 code came on after a recent oil change and flushing my engine with seafoam.
The info I've gotten from my auto parts store is that it's one of the oxygen sensors, HO2S or Bank 2. I believe, if my research is correct, that this sensor is post cat. Looking down from the front of my engine I can see 2 sensors after the cat pretty close to each other.
Can anyone tell me which one I should replace? They looked to be only about 8 inches apart. Is there anyway to test them or should I just replace each one? Could this failed sensor be the cause of my engine running a bit sluggish? Thanks
