Help Disable Automatic Door Locks
58K views 10 replies 6 participants last post by  nycazncarguy
Is there a programming sequence that will keep my 2002 Camry from locking all doors when the vehicle is put in drive/reverse. I realize this is considered a safety feature but I prefer to lock them myself.
Thx
jcs
#3 · (Edited)
I need to do this!!! Pls pls pls psl give me the instruction for this!!! I have my notes somewhere but I couldn't find it!!! :facepalm:
Well once u disable the auto lock when shifting from P to R/N/D then that'll solve his problem. But me, I need it to lock when I start moving. I don't know if the instruction is the same for gen 5 and 6 though...
From Page 42,43,44 of my manual.
AUTOMATIC DOOR LOCKING
You can select the following functions:
 Locking linked with the shift position
All doors are automatically locked when
the selector lever is moved out of “P”
position.
 Locking linked with vehicle speed
the vehicle speed goes above about 20
km/h (12 mph).
You can set or cancel the automatic
door locking functions:
Be sure to apply the parking brake when
performing the following operations.
To select the locking linked with the
shift position:
1. Close all doors and set the “POWER”
switch at ON.
2. Shift the selector lever to the “P” position.
3. Within 10 seconds of turning the
“POWER” switch on, press and hold
the driver’s side power door lock
switch in the lock position for 5 seconds
and then release.
The doors will be locked and unlocked
to indicate that the function is set.
To cancel the function, do the above operation
again.
vehicle speed:
switch at ON.
2. Shift the selector lever from “P” to the
“N” position.
and then release.
again.
AUTOMATIC DOOR UNLOCKING
 Unlocking linked with the shift position
All doors are automatically unlocked
when the selector lever is moved to
“P” position.
 Unlocking linked with the “POWER”
switch
when the driver’s door is opened within
10 seconds after the “POWER” switch
is set from ON to ACC or OFF.
door unlocking functions:
To select the unlocking linked with the
shift position:
switch at ON.
switch in the unlock position for 5 seconds
and then release.
again.
“POWER” switch:
1. Close all doors and turn the “POWER”
switch at ON.
“N” position.
and then release.
again.
I didn't know I could do something like this myself, will have to give it a try :D thanks
#9 ·
Now whenever me or a passanger opens the door while the car is in D (while stopping of course I'm not stupid), all doors will automatically lock themselves up when the car starts moving. :D
Locks when shift out of P and unlocks when shift to P. I'm good! :D:D
