Hi all!! I am hoping somewhere here can help me out. I was driving my car home today and the engine lite popped on. I don't know if its related but yesterday it made a noise like I ran over a stick.. couldn't see a stick anywhere.
I know I have to find the code, but is it the same procedure as this? I found this searching the forum.. but don't know if it applies to my car.
"you need to check the codes. behind the battery, you will see a DIAG diagnostic port. it is black plastic, about 1 inch by 1 inch. pop it open.
in side, you will see a bunch of terminals. put a short wire, or paperclip between t and e1.
then get in the supra, and turn ignition to on, but do not start.
the check engine light will flash. count the groups of flashes
3...2.......5...6.......2....1...............3..2.......5..6.........2...1 repeating...
this tells you the codes 32,56,and 21 are stored in your computer. goto supras.com and check what the codes mean, and what you need to fix.
Thanx Keggy
:bash:
Thanx Keggy
:bash:
