help with Camryn! bubbles in radiator.
1.9K views 10 replies 5 participants last post by  KoltonMcCallister
I've got a bit of a problem aha. I recently changed the radiator in my car Camryn. His last one blew after I used some blue devil. Seemed to fix the head gasket. Bubbles disappeared immediately. Now with the new radiator, I put water in him and he was fine. But with a little under 50\50 antifreeze (about 30\70 the 70 being water) he started practically foaming. Now I'm no rocket scientist but when people have foam coming from the hole they drink water from... Well that's bad. Could the head gasket issue be back? And why when I JUST changed the radiator? Camryn is like this alot BTW. As soon as I fix something, something else breaks. At least he gives me an excuse to fix him up! ;)
1994 v6. First year for the 1mzfe. But what's funny is the bubbles disappeared after the blue devil. Then the radiator blew, and when I put a new one on and filled it with water there was no bubbles. Now that there is antifreeze in him he bubbles. It's odd, and I don't know why water is having a different end result than antifreeze. If it helps, on cold mornings when its cold white smoke comes from the tailpipe. But only when he's cold and when the air is cold. There are SO many problems with him lol
Quick question. What's the easiest way to check for a head gasket leak with only basic hand tools? My dad told me to put my favorite and nicest shirt over the tailpipe and see if it smells like antifreeze. (But I can't see how it would considering how he hasn't lost any coolant) (but he could just be consuming it too slow for me to notice?) None of the common signs are there except for bubbles in the radiator. And he smokes white smoke, but not much and only when he hasn't been ran in a while and its cold outside. I could
compression test him, but I don't have a tester.to be honest if I remember correctly I don't even have a socket set long enough to reach through the valve cover and extract a spark plug. :\ no mayonnaise oil, no oil deposits in my water. With money being sort of tight, i need a sort of.. (What my dad calls) "shade tree mechanic" method that isn't just checking your fluids. :\ any help would be appreciated haha.
Just cause it isn't mixing with oil doesn't mean the head gasket isn't blown. It completely depends where the head gasket failed. I've seen them fail between a water jacket and oil galley so coolant and oil mix but nothing ever gets into the combustion chamber. In your case it's failed between a water jacket and the combustion chamber.
