Whenever I'm at high RPM i hear a high pitched ringing sound that will cut out straight away as the gear shifts or if I ease my foot on the accelerator. Through a bit of research it brought me too checking the Transmission fluid and specifically the transitional fluid. I eventually found that my 1.6 3 speed auto has a separate tank for the transitional fluid but while I find lots of references to it, no clear info on where exactly this is on the underside. Can anyone help, maybe with some very handy photos??
In addition to this, I did decide to check my transmission fluid as I'm not sure if this has ever been changed in the 5 years I've had the car. To my surprise i found it to be very full (even possibly over filled) with the fluid being the pink colour I was hoping to see. So given this, is it even worth checking the transitional fluid? I assume so if the 2 are totally separate and there could be a leak?
Alternatively if anyone has any other theories as to the high pitched ringing sound i'd be keen to hear!
