Redline Tuning have been designing and selling hood QuickLIFT Systems since 2002. I'm seeing a bit of weird info, so I'll just post some facts about the systems. First, we have over 400 unique applications - we try to release a system for every vehicle that has a prop rod... we always have about 50 vehicles on our development list as new cars/trucks come out all of the time, as well as rolling changes that require investigation. We always look to release a bolt-in system, one where you can just mount a bracket in locations where bolts exist. However, this is not always possible - newer vehicles now use headlights that wrap from the front all the way through the usable inner fender. They also have plastic cladding and many other components that interfere with mounting locations that would make a system 'bolt-in'. So, our long-standing philosophy is to only release a system that works (I know, imagine that) - one that does not compromise function for the sole reason of being a bolt-in system. Sometimes we can get certain geometry to work, yet the function is not there - example of that would be one where the lifting angle is so low that the hood only lifts from the top few inches or one where the hood just will not stay open. We always want 20-30lbs of force at full open position, we want the hood to lift from mid-point or lower unassisted.
For the 2020+ Highlander Hood QuickLIFT System, we have hybrid mounting approach. We have found a hole in the GOR near the front of the headlight that allows us to use our patent pending blind insert to hold a ball-stud, and the hood bracket is then riveted into the position it needs to be for proper function and lifting height. To install our hood bracket we do not use standard rivets, you cannot buy our rivets at the store. These are used in aircraft and high-end automotive applications, these rivets are the absolute best way to attach two similar or dissimilar materials... we have been using this method for over 20 years and they should not be swapped out for a 'better' attachment method. They use the smallest hole and bind the bracket to ANY material (Steel, Aluminum, SMC, Carbon, fiberglass, etc.). We choose locations that strong and needed for proper lifting function.
Lastly, closing your hood. Stop over thinking this. Having struts on your car is no different than having a PITA prop rod, when it comes to closing your hood. You can pull it down and slam it, you pull is down and let it rest then dual palm shut. You can do whatever you want, the OEM puts rubber bumpers to stop the hood and the latch is the final physical stop, it cannot close further when it engages. You weren't going to hurt your hood with a prop rod and you are not going to hurt your hood with struts attached. It has absolutely no bearing on the hood. The lifting force reduces to zero in closed position, the hood and struts are parallel. The hood is attached to the car with a hinge assembly - it is strong, meant to keep your hood attached when you run your truck into a semi, it won't come off. This is ALL that we do here, design and manufacture all components, release the best possible QuickLIFT systems for every vehicle we can get our hands on. If we do not have the vehicle application, just contact us - we are in Ann Arbor, Michigan and a new system is free to any volunteer who comes by and spends a couple hours with us while we develop it. Any questions, just let us know.... I do not monitor forums, so feel free to contact us directly with any question, concern or otherwise about our products.
Thanks,
Brian
Redline Tuning
