How to remove rubber tire marks on your car?
6.5K views 16 replies 11 participants last post by  corollacoaster
A large, heavy piece of 18-wheeler truck tire was thrown up from the freeway and landed hard on my roof. I have a white Camry. Fortunately, it didn't dent the roof. But it left the ugly rubber tire track mark in the pic.
What is the best way to remove this rubber mark?
Everyone needs to have a couple of emergency products for paint cleaning. So when you get contamination of any kind, you just try them all one by one. If you don't have any, a "bug and tar remover" is a good start. Then there is "cleaner wax" products. Just pick the cheapest. Rubbing alcohol is another good one but be careful with it. Some paints may not like it..
Thanks for the suggestions. The auto parts store had two of the mentioned products: Meguiar's Bug and Tar, and Meguire's Ultimate Compound.
I started with the Bug & Tar remover, which took most of it off with the first application. The second time, it took almost all the rest off except for a stubborn spot that probably took the brunt of the impact. Pic attached.
I'll get that last little spot off tomorrow, hopefully with the Ultimate Compound.
#9 ·
Good job! I see some scratches on the photo, and Ultimate Compound should improve, or almost eliminate them depending on their depth.
#14 ·
Bug and tar is good option, lighter fluid is also good for junk stuck to the paint. Lighter fluid is not as strong to paint as gas would be, I consider lighter fluid to be safer than gas. This is chemical reaction, so small soft cloth sit on top of the rubber for 30 sec and removal rub, then soak again. Rubber is made of oil, tar made of oil, so using a solvent is good to get this off.
Brasso.... this idea not sure of. This is a brass and metal polish. Made for removing oxide from metal and leaves a small amount of protective finnish on the bare metal to slow oxidation a bit. Never read about this for paint or car use. I have 5 containers of Brasso on hand.... get from the county recylcer. I would not even try this.
Once rubber is gone, a paint cleaner is what I would do.... on that spot.
Then clean the whole roof so it all matches.
Polish Compound. . .. is the less agressive one
Rubbing Compound is a bit more agressive.
After rubber is gone, you cleaned the paint, see how it looks.
Any scratches, swirls, (hope the clean coat is still whole)
Then ck youtube for instruction on how to use the polish compound..... can be done by hand
once done.... then wax your car for the summer season.
I assure you, I've had consistent success with Brasso to remove light scratches in car paint, without staining or damage to the clearcoat. Try it on that little scratch on your car that's been annoying you for a while. I even polish oxide off my headlights with it, leaving them clear as water, and even if the headlight is sunburned bad enough to require sanding, the Brasso will restore a smooth and scratch-free surface. I suggest melting the rubber with a dab of vaseline. It will attack the rubber and that's why you're warned against using it during marital relations and using rubber condoms. I never tried lighter fluid. It evaporates very quickly, but maybe it will last long enough to do the job.
#16 ·
Interesting event and all survived. Best to consult a Professional Auto Paint Shop, reputable Collision Repair Shop, sometimes a long-time established Professional Auto Detailer will know what to do.
Otherwise, you are just Experimenting and Hoping the rubber marks can be removed then you may cause more damage to the roof top body paint.
Glad you're safe and the vehicle is still drivable.
