1987 base pickup.
I need to replace the sealed beam headlamp on the passenger side, but one of the four screws (one on the bottom) which mounts the bezel to the metal piece behind the lamp is stripped. I was just barely able to remove the other lower screw, but this one will not be turned. I want to use a rotary tool to cut a slot in the screw so I can put a flat blade screwdriver in there to turn it out, but the plastic grill is in the way and I need to remove it. Problem is I can't figure out how to remove it without breaking it. I can remove all the fasteners from the top of the grill, but I'm having difficulty removing the bottom part. I've successfully pinched in two of the lower fasteners on the passenger side, but I notice that side still won't budge. Obviously I'm missing something. I've looked on YouTube and there isn't any video I can find for this generation. Lot's of 90's stuff.
Anybody know what I'm missing?
