Hey Corolla Enthusiast
I have read a couple of threads here where a lot of you guys were debating changing the AC Panel Lights. Well I did mines since one bulb burned out and took Pictures to share with the rest of you. All the tools you need are a Flat head screwdriver and a Philips head Screwdriver. Also The replacement Bulbs and Color Gels for color change.
This is a Pic of the panel. Plain and simple!! 2001 Corolla Same panel from 1998 to 2002 no change in it.
Step 1 Remove the Radio Panel.
It will have Electrical Harnesses for the Hazards, Clock, and Defrost (1998-200)
Step 2 Remove The radio. It is bolted with 4 screws. Remove them after this pull the radio out.
These are the screws holding the radio in place.
Place radio on top of dash. If you want you can disconnect all electrical harnesses to the radio and place it on the passenger seat. Its up to you.
By taking out the ashtray you can Remove the bottom Bezel With your hand. If it does not come out. Use a flat head and pry it out.
http://s298.photobucket.com/albums/mm259/trijet727/?action=view¤t=d8-1.jpg
once out, There are 2 screws holding in the AC panel. Remove them. Gently pull out the ac panel slightly out don’t pull it out all the way.
Here is the left side bulb holder showing its harness. Twist and remove. If you have big hands (like me lol) A pair of needle Nose pliers helps a lot!
here are the bulbs. Remove from socket and use replacement bulb.
This is the Toyota part no for the replacement. Bulb 74 does not work. Tried it. Bulb 194 also does not work tried it as well. This is the only one that will fit. According to the Toyota parts clerk. They had one left in stock!!! Guess who bought it?
test before putting the assembly back together.
installation is the reverse of disassembly.
This is for all of you who have Corolla S Models and HATE the green ac panel lights and red dash that don’t match at all. This applies to all models too so If you want the color changed..
available at pep boys
put the condom on the willy!
test and replace!!
Guys I’m not a mechanic!! Sorry if I misnamed a few parts in this post However hope this helps out all who want to change their dash bulbs, I did it with the car on and AC Blasting While listening to music. It is not recommended as you will be working with electrical parts.
Let me know What you guys think. Hope it gelps our anyone trying to do this easy project.
test and replace!!
