Either I'm not reading you post correctly, or some of these people responding didn't read your post at ALL!?!?!
Let me see what I can clear up for you
The size of inverter you will need will depend on how many Watts your laptop adapter takes +10%
So if you look at your laptop power adapter and it says 120VAC 240 watts then you know you need an inverter that's 240 Watts +10% or more.
If it lists AMPS instead of Watts (IE: 120VAC 2.0 Amps) then convert the amps to Watts via calculation below...
The power
P in watts (W) is equal to the current
I in amps (A), times the voltage
V in volts (V):
P(W) =
I(A)Ă—
V(V)
NOW you can convert that wattage into amperage on your DC side so you know how many AMPS it will pull at 12Volts (The adapter in my example lists 120Volts @ 2 amps)
Since you trade volts for amps and vice versa as we decrease the voltage with the same wattage the amperage MUST increase.
So 240+Watts at 12 volts is 20AMPS!!!
The wiring in this 8th gen through the cig lighter is about 4 amps and 6-8 MAX (And honestly looking for trouble much past that.
Even though you may have a 15amp fuse, the wire in this car is REALLY small at the cig lighter.
So if you have a super tiny super efficient laptop then you MIGHT be able to get that down low enough to run off the Cig lighter but to be on the safe side I would run power directly from that battery to be safe.
Hope that made some sense, let me know if you have questions..
