well, honestly, its kind of annoying to use. it takes more turning action /c its smaller, and it is one of those cheap ebay wheels, so the top part flexes, and pretty bad too. it holds up fine for driving of course, but any sort of heavy impact or full braking = bend, unless you move your hands to the center sides of the wheel to brace... but, it does look better, but, its not worth doing unless you get a quality steering wheel. if i could do it again, id find a better wheel or perhaps an oem replacement.
but anyway, here it is:
1. make sure your front wheels are straight, then remove the cover. unscrew the mounting frame from the wheel, there are little screws behind the wheel, on the bottom and top. then unscrew the wheel, itll be tight of course.
2. youll see this in like 5 mins
3. mount THE HUB, and test fit it wth the wheel to make sure its alaigned correctly.
4. connect the horn, line the wheel holes up with the center plate and hub, and drive in the hex screws, and your done.
not a bad mod to do, but make sure its a strong wheel. also, cheap ebay steering wheels may look rigid, but in fact there not, not the ones of this design. its also small enough that it would work out well on go cart or even a bumper car. ill be looking for a new steering wheel soon, and as soon as i find one this wheel + hub kit will be up for sale. :werd:
