Instrument panel lights out
15K views 2 replies 3 participants last post by  Zembonez
My 2002 toyota sequoia instrument cluster lights are out,i cant see speed,gas,temp,rpm at night. All five green lights don't light up, every thing else does, turn,engine drive,park, everything except the five green lights, so the first thing i check was the interior fuse panel and panel 7.5a fuse was blown out, so i replaced it and as soon as i turn my head lights on to see if the instrument panel lights up the fuse blows out instantly i did this sequence three times and all three times it blows, not sure what it could be.
Has anybody gone thru this problem
If a fuse keeps blowing it can be a bad ground or a hot wire is grounding somewhere like a break in a wire or a spot in the wire that has worn through. Get a volt meter and start checking the wires in the circuit. Sorry, I can't be of more help.
Good luck,
JohnB
