I have a 2023 Camry Nightshade which came with a 7" display(non-JBL). Picked up a 9" display (non-JBL 86140-06A70) on eBay and did the upgrade. It was plug and play, easy to do and have been happy with result.
The one issue that randomly occurs is an occasional (once every few weeks) white screen at start. I've researched the previously (often) posted "white screen of death" but I don't think this is my issue because when the white screen occurs : 1) the rear camera displays perfectly fine in reverse (my thinking is if the issue were a failing display ribbon cable, then the rear camera would also not work) and 2) if I restart the car, the screen boots up normally.
As I mentioned, the headunit was purchased off eBay and was never installed in another car. It came in the original packaging and visually looked new, without any imperfections. After install, it updated to the latest firmware. I'm using CarPlay and have connected a 2023 Ottocast Pro Air 2.
So, I'm looking for input on what the issue might be? Could it be display? Could it be firmware? Could it be the Ottocast?
Thoughts? Thank you
Thoughts? Thank you
