loud brake squeal only when backing up/reversing
7.9K views 4 replies 3 participants last post by  maonca
Hi all and hope everyone is keeping well,
Lots of discussion about this subject although each case is slightly different than mine, so bear with me... its on a 2012 Camry and posting here as it should not be a make/model/year specific issue.
Issue: The driver side front has a loud squeal when backing up with either no brakes applied or slight brake applied, not just in the morning but whenever I am backing up. No noise when driving forward which brakes fine.
Background: Did my own front brake job with new rotors, pads w hardware
  • greased the shims, pad top/bottom edges, pad backing plates
  • cleaned & lubed all slider pins.
  • degreased the new rotors.
  • unsure what went wrong but driver side upper caliper bolt came off and was lost after a few weeks/months (passenger side was good), lower bolt was loose and about to come off (originally did it to torque spec). Re-did it with blue lock-tight + torque spec so it should be good now.
  • re-checked everything, bracket/bolts are on fine, caliper/bolts on fine, nothing loose.
  • dust cover not touching the rotor
  • I see enough clearance between rotor and bracket so that should not be the issue.
  • wheel turns fine, although need to test-turn it in reverse when on the jack this weekend.
  • feels pretty good when driving forward and brakes fine, no pulling to either side, no squealing etc.
  • caliper is fine as it retracted without issues when doing the brake job so unlikely it is seized.
  • was fine prior to brake job so something I did or with the components or both...
Any experiences or thoughts around this?
Hi Petrol, you just solved the issue!
After getting someone to listen to each wheel outside the car while I backed up, they confirmed its the rear passenger side brake, which both sides are actually due for change as well (will check e-brake for sticking during the change as well). I always incorrectly assumed the front because it happened after I did the front brakes...
Once again, thanks for your reply.
maonca
