Need help fiding a front grill
3.8K views 18 replies 6 participants last post by  mcoayla71
I bought my daughter a 2023 toyota corolla LE 2.0 and she was super excited with her first new car.
With less then 5k miles on the car an old man decided to back up his dodge ram truck at a red light where my daughter was behind him and the old man damaged the bumper bit mainly the grill.he said he didn't see her.
My Daughter being that it was her first accident she didn't call the police and exchanges telephone numbers and name with the old guy.
To make a long story short. The old guy wrote me a check because he didn't want to get the police involved because he was from Canada and we live in Florida.
I took the car for a quote and I was quoted $4,500.
But they couldn't get it fix until 3 months later because they were very busy.
So I decided to take a look under the hood and behind the bumper to see how bad the damage was.
As I looked for damage the obvious was the front grill was cracked and need a new one.
Behind the bumper I could see that a bumper support bracket that's in the middle of the bumper and holds the bumper in place with a clip was bent out of shape.
I straighten that support as best has I could. But yet the bumper seems to be off by an 1/8th of an inch or so.
The hood closes, but it is just creating a lip with the bumper cover and the hood. Before the damage it was a smooth transition from upper bumper cover to the edge of the hood.
I came to the conclusiĂłn that the upper radiator support is probably slightly pushed back and that's why the upper bumper cover and hood are creating a lip where there wasn't one before.
Tomorrow I will tie a rope to the part of the upper radiator support and try to pull that 1/8th of an inch forward so the hood and bumper are smooth again.
But my question is.
Where besides The Toyota Dealer could I find the front bumper grill.
The one in my Daughters car has the horizontal lines going across the front grill.
The ones I find online are the honeycomb front grill. Wich in my opinion look better then the one the car has now.
The honeycomb grill is on Ebay and when I click on the model of my Daughters car it says that it doesn't fit.
But outer shape of the grill looks like the same shape as the OEM one in my Daughters car.the only difference is that the OEM in my Daughters car has the horizontal lines across the grill and the on Ebay has honeycomb grill.
If anyone could help me with this I will be very appreciated.
Thanks for your help and sorry for the long post.
#2 · (Edited)
Check with LKQ, car-part.com and row52 for used parts. You’ll be surprised on used versus new pricing. They’ll be close. Is there a camera or radar in the grille? If there is one, you’ll need to get it recalibrated.
Compare the pricing for the radiator core support rod too. 1/8” isn’t much, but you could try to massage the core support if you can use a dolly behind the top and front edge and smooth it out with a body hammer.
The LE bumper is different than the SE bumper.
partsouq for a part number, then I'd call dealerships to see who had what for inventory... likely nobody since the cars brand new.
if the previous generations had the same kinda grill I've had good luck with aftermarket ones from eBay.. usually they're styled to look blacked out or billet aluminum, different style plastic etc... see if anything exists for a previous year that might fit and have your daughter pick it out.. tell her it adds 10hp
The shape of the 2020-2022 grille are basically the same with the 2023. It's just restyled from honeycomb to slats so both of them are interchangeable. The 2023 slats grille doesn't match the honeycomb on the Toyota emblem like the 2020-2022 had. The grille is new for 2023 so probably you won't find the same one yet or have a look at your local junkyard or online used part as other have mentioned.
I noticed the same thing. That the one on my Daughters car looks like the same shape as the one that are Honeycomb.
I see that it says 2020 2022 LE grill but it looks like the exact same shape.
I want to order it but I really hate returning things when they don't work out or right right.
I actually really like the Honeycomb one better. What do I do?
#9 ·
I found the pictures of the damage to my Daughters Corolla
The SE grille is a little different because at the lower ends it extends a few inches on either lower end side.
There is an LE Grille that looks like the SE grille but it's shaped like the LE grille but it's made for a 2020 to 2022 corolla.
I looks like the same exact shape as the one on my 2023 corolla LE grille shape. The only thing is that is not made for the 2023.
#13 ·
I just checked google, and the dealerships do not list a lower grille for the 2023 models as available. 2022 looks similar, but based on the images I’ve seen, the tabs are different for 2022 and 2023.
Op, best to hit a dealer. The aftermarket ones may fit, but is a long shot.
