Hello all,
I have a 2007 corolla with 160K miles, strong runner with no problems to date.
On the way home last week the temp gauge started swinging erratically from normal to cold, and the ac system wouldnt run for a short period of time. There was also a bit of a high speed engine surge which happened 3 times within an hour of drive time.
replaced the fuel pump and relay (I realize that this was probably unnecessary, but was more of a preventative step) and the temp sender.
Problems now are as follows;
1. Will not start when cold without starting fluid
2. Fan is running at high speed even when engine is stone cold
3. Once car starts and runs for 5 minutes it runs perfectly and will restart normally while warm
4. the colder the car gets, the harder it is to start
5. P0118 code is persistent even after clearing the system
6. tested two known good temp senders with no change
7. the connector and wiring look perfect
8. AC is running fine
9. Water pump and thermostat are 1 year old with no signs of issues
Was going to check for 5v at the connector, and then jumper the connector to see if max temp is registered at the ecu ( with obd scanner)
I am thinking the only possible culprits are an open circuit or the ECU, but I wanted to throw this out to see if I am missing anything. I am willing to get the two day Toyota tech access if needed for diagnosis.
Any ideas? Am I missing something? I really appreciate any help anyone could provide, as I need to get this fixed.
Thanks for your time
Craig
Craig
