Noise
6.8K views 23 replies 11 participants last post by  tprochaz
My 2021 Venza LE is less than a month old is making a grinding noise mostly when taking a corner.
Dealer has no clue without a warning light coming on.
This only happens at low speeds.
#9 ·
First, if the vehicle does this all the time, take it to the dealer, take one of their staff for a ride and reproduce the problem. A verbal description isn't adequate. If there's something wrong, you want it fixed now, before it becomes a bigger problem.
1) Wind down the front window. When you're on a turn, is it coming from the inside wheel or the outside wheel?
2) Does it make the sound for low-speed turns, high-speed turns, or all turns? (Note 1)
3) Look at your brake rotors in the morning. Is there surface rust on one or more rotors? Especially look on mornings when it rained or the humidity has been high? If there is rust, do a couple HARD stops in a straight line so you KNOW the brakes are doing the stopping. Does the sound now go away when you're turning? (Note 1)
(Note 1) Since hybrids also use regenerative braking, the mechanical brakes don't get used nearly as much as conventional vehicles and rust accumulates on the brake discs. I believe the Venza uses differential braking for slow-speed, tight-radius turns (part of the vehicle stability control - VSC). When the brake pads lightly contact a rusty rotor, they make a grinding noise until the surface rust wears off.
#20 ·
My wife reported this same grinding noise recently. It has happened TWICE now, both times in the same exact spot on her commute!
It occurs when braking normally and turning right into a short, somewhat tight low speed turn. The noise scared the crap out of her. One time it occurred at the beginning of the turn / early in the braking process and the other time was near the end of the turn / end of the braking process. The noise only lasts for 1-2 seconds.
Below is a picture of the turn and the locations along the turn the noise occurred.
Just under 2,000 miles on the car and this is the only 2 times it’s happened. I am thinking it’s some fringe condition that is invoking ABS or stability control. Will keep an eye on it and engage the dealer if it continues.
338265
#22 ·
This happens to my Venza as well! The grinding on the turns and then sometimes braking going straight more of a clunking noise. I have complained to the dealer, and next service I will try and get them to look again. Glad I am not the only one who has this problem, everyone thinks I am nuts until they hear it as well. Let me know if you ever find anything out!
#24 ·
Heard as well on my wife’s Venza. She was going slow on a gravel side road. Dealer thought it could be the sensitive anti-lock brakes which makes sense since in both instances she was lightly using the brakes. so when you hear the noise are you using the brakes on an uneven surface? Is so could be the anti-lock brakes which is a rattling type noise.
