The "infamous taco-lean." That pisses me off. Not that you said it, but that Tacoma has that reputation. Where was "the infamous taco-lean" when Consumer Reports and the legions of loyal Toyota owners rave? Do you just not complain about these things? Or is this dirty little secret just not worth taking the arrows from the defenders of the brand? I'm obviously not the only one bothered by it, since others are putting in their own fixes of choice. You shouldn't have to.
Fitter565, I appreciate the explanation of the spacers, but my confusion with your explanation was that you called them struts. McPherson struts don't come apart when you loosen the three bolts. These do, that's how you put the spacers in.
The problem is, it's the wrong adjustment for a lean at the rear if it's already level at the front. The adjustment needed is for the ride height on the left rear, either a higher spring rate or a spacer.
1st Cavalry, I can do at the rear what you did at the front, change the spring rate by bumping up the pressure in the air bag for the left side. That's not the point.
If the spring rates in front are correct, it should be level there unless the sway bar links are not equal.
So I call B.S. on Toyota. This is a defect.
