Call it boredom or stupidity, but I've decided to turn the Camry into a budget off roader. Ultimate goal is to enter the Gambler 500, but thought it would be fun to enjoy it in the meantime. Now that the car is running good (well, good enough), and the new springs and struts raised the height more than I like, now is the time.
I've been searching for a decent set of rims and tires from a Ford Ranger or Jeep with the correct bolt pattern, but no luck for a while. With the help of a local parts yard, I took a Ranger wheel and learned a 215 70 15 tire can fit without major interference (even though the suspension is at full droop, and this was on a 1997 and not a 1996).
But what fun would this be? I ended up buying a set of used rims/tires off of a Jeep Cherokee, so this weekend I'm hoping to marry them together with the necessary body work. Tires are currently 195 75 14, and the new are 235 75 15. The overall height is about a 4" change, so this will give the car an extra 2" of ground clearance.
Yeah, width is also interesting with not enough offset, so I have 2" spacers on their way. I hope this will be enough to clear the struts. Though not sure if this is a bad omen, but when I started to lift the back end from the jack point, the rusty rocker stared to fold in, so had to find a solid lifting point further inboard.
This weekend, my plan is to delicately remove the lip all the way around the wheel well and cut about an inch into the fenders. Go from there to see to see how much more is needed. I do have another trick up my sleeve for extra height (thank you Google search for having me stumble into someone else that already lifted a Camry.
Stay tuned.
Stay tuned.
