Owner of 2009 Camry LE w blown head gasket Is it possible to swap 2006 Avalon Limited engine
1.6K views 7 replies 4 participants last post by  Demoncow666
New member to Toyota Nation. I need resources to determine if a 2006 Avalon Limited engine can be used in a 2009 Camry LE chassis. Can anyone point me in the right direction?
Anything's possible with enough time and money... Does the 2009 currently have the I4 or the V-6? The 2006 Avalon only comes with the V6. Transmission in the 2009 would have to be compatible with the new 2006 engine, as would the ECM, Sensors, and the Engine wiring harness at the very minimum. Is there a particular reason that you don't want to repair the blown head gasket? Are you after more power?
The V6 is the same used in the V6 camry, but usually Id prefer to find a motor FROM the specific type of car I am placing it in due to some chassis / electronic / wiring differences. etc..
The block / heads from the Avalon though are all likely the same as the one from the V6 Camry model. Youd have to double check opn things like sensor palcement etc.. as a 3 year difference as wel las the model difference may have different revisions or provisions for accesories and sensors...
this is for the 06 avalon:
  • 2005-2007 Toyota Avalon - (3.5L, VIN K, 5th digit, 2GRFE eng, 6 cyl)
  • 2006-2011 Toyota RAV4 - 3.5L (VIN K, 5th digit, 2GRFE engine, 6 cylinder)
  • 2007-2009 Lexus RX 350 - (3.5L, VIN K, 5th digit, 2GRFE eng), w/o oil cooler
  • 2007-2010 Toyota Sienna - (3.5L, VIN K, 5th digit, 2GRFE eng), w/o oil cooler
  • 2008-2009 Toyota Highlander - gasoline, 3.5L (VIN S, 5th digit, 2GRFE engine, 6 cylinder), w/o oil cooler
  • 2010 Toyota Highlander - gasoline, 3.5L (VIN K, 5th digit, 2GRFE engine, 6 cylinder), w/o oil cooler
  • 2011-2013 Toyota Highlander - gasoline, 3.5L, VIN K (5th digit, 2GRFE engine, 6 cylinder), w/o oil cooler
  • 2012 Toyota RAV4 - gasoline, 3.5L (VIN K, 5th digit, 2GRFE engine, 6 cylinder)
