Your car is adding an insane amount of fuel to the engine to keep it running. This could be due to many factors: A vacuum leak, a bad MAF sensor, a bad air-fuel ratio sensor, a bad oxygen sensor, bad fuel pump, bad fuel pressure regulator, bad fuel injectors, etc.
What is your MAF sensor reading (in grams per second) at idle?
