I need some help with what I think is a rattling PCV valve.
I replaced the PCV valve (with OEM). The old one looked dirty, but still rattled when I shake it. However, now with the engine at idle, I can hear a metallic clicking coming from the area of the new PCV valve. It's difficult to verify, because it's behind the intake manifold, but since I just replaced the PCV valve, what else could it be? The clicking also seems to sync up with the engine cycling..
My corolla has been burning 2 quarts of oil every 5000 miles since 80k miles. It's at 100k now. I guess worst case is there's a broken valve seal and I'm getting high pressure in the crank case. I also heard it could be a vacuum leak. I'm going to try and check the vacuum pressure, but is there anything else that I should be looking for?
*Update. I rigged a gauge from a brake bleeder pump into a tee in the vacuum booster line and it ran pretty steady at 20Hg. Accelerated a little and it hit 25Hg and came back down. It flutters a little at around 1 Hg, but I'm wondering if my vacuum rig is a bit leaky itself.
Here's a recording of the clicking:
