So I bought the Pedal Commander Throttle Controller. Cost a pretty penny, $300. I will update this post as I drive it more as the first day won't tell much. Super easy to install, no cutting of any wires. When you order it you give them your vehicle information and it comes with the correct plugs for the throttle pedal. First impressions of it are pretty good. You can most definitely tell the difference when touching the pedal, instantly gets more sensitive. There are 4 modes: Eco, City, Sport, Sport + and each mode you can adjust the sensitivity up 4 or down 4 to really customize the feeling.
(The wires are going the other way now for where I mounted it. I took this picture when I initially installed it)
I installed it on the dash next to the steering wheel and ran the wires through the 1st empty plug. To get this plug out I had to pull the panel off on the left side to get behind the dash area.
I drilled the side of the blank switch plate out so the cord would run through it and look as clean as possible.
Here are the 3 places you can purchase it from (I purchased mine from amazon):
Amazon:
https://www.amazon.com/Pedal-Commander-throttle-response-controller/dp/B00O82ZD62
Ebay:
http://www.ebay.com/itm/Pedal-Commander-throttle-response-controller-for-all-2005-Toyota-models-/301753071486?fits=Model%3ACorolla&hash=item4641e2777e:g:iT0AAOSwzhVWqsv1&vxp=mtr
Pedal Commander:
https://www.pedalcommander.com/brand/toyota/corolla-11th-gen-2014/1-8l-4-cyl-132-hp/
If you would like some more technical insight on how it works, see their blog page that tells more about it:
https://www.pedalcommander.com/blog/
Amazon:
Ebay:
Pedal Commander:
