Symptoms: After a prolonged period of time from stopping the car(~8 hours), when I start it(turns over just fine) it feels and sounds like there is a dead cylinder. When this happens I give it some throttle to ~3000rpm where the engine misbalance is most felt. After ~45seconds the cylinder seems to come back to life and all is well. If at that time I shut off the car and start it again, there will be no problem.
I have already ruled out the fact that it is cold around here, becuase it was 50deg in my garage when I started it this morning. I have checked the plugs and wires and dist cap and they are all good. I have ruled out fuel pump because there is no loss in power after the cylinder 'comes back to life.'
I believe it to be a bad battery charge or holding charge or something to do with the battery, whereas I have killed the battery several times this past month. Also it seems the battery will not hold a charge; whereas after 15 mins of steady driving I will turn off the engine and play some music for ~3 minutes and try and start the car and the starter will be very very weak. Perhaps the battery is having a problem because I kille dit soo many times and it is cold outside?
Thanks a bunch guys
engine code: 3S-FE
Thanks a bunch guys
engine code: 3S-FE
