I am looking to replace struts on a 2009 Highlander Base AWD - 6cyl.
The pre-loaded struts look like an excellent way to go instead of removing strut from spring and reinstalling new strut inside old spring. Cost is just a bit more than a strut but assembly includes new strut, new spring, mounting bearing, etc. and you don't have to mess with coil spring compressor tools.
There appears to be only one manufacturer / supplier of these pre loaded assemblies - FCS. Anyone selling them on line is only offering that brand. However, it states that on the rear these won't work if you have 3rd row seating. However, there are no such limitations for struts or strut bearings regarding if you have, or do not have, 3rd row seating.
I am guessing that the coil spring OEM for a 3rd row seating may be a little different then the coil for a Highlander without 3rd row. Maybe a little taller or stiffer? However, I can't imagine that the actual suspension is any different, so I am thinking that maybe these pre loaded would install correctly in a 3rd row seating vehicle.
Has anyone tried these pre-loaded in a 3rd row seat vehicle and did they work out OK?
