Just curious to see what y'all are running and to see why/which one seems better?
Do you think there's a big difference between the extra adjustable point?I have Progress Technology and it is great. Cusco is not adjustable. Progress technology is, and Whiteline is even more adjustable (3 points).
60.4022.2 | Replacement Bushing, PairYou can purchase replacement bushings here
https://www.progressauto.com/product/60.4022.2-replacement-bushing-pair
Do you have any recommendations for grease to use (besides OEM grease packet which is only good for 1 time)? Or where could I purchase more OEM grease packets?Bushings are a wear item, checking and regrease every 6 months may be necessary in your harsh climate.
You can purchase Energy Suspension grease on Amazon as a 3 pack. This isn’t what we use but is comparable.
Replacement 27mm Greasable bushings -After 2 years of using the Progress Tech Rear sway bar, I started hearing squeaking from the rear. Dropped the bar to see the bushings were somewhat worn. I asked the questions to Progress Tech and they delivered the following:
Where can I purchase replacement bushings?
What is the recommended maintenance timeline for greasing bushings?
IIRC whiteline rear sway bar is 24mm and progress tech is 27mm, with comparable prices you're better off with getting a local supplier to order progress tech.Ask anyone's who's ran there parts in auto-x. They replace them with another brand as soon as their discount sponsorship is up because they don't perform. Just slightly better than stock, with half the shelf life. I've had nothing but bad experience from whiteline, including press in bushings being knocked out of control arms with just regular driving. Not even HPD uses, just normal driving.
Progress, Ebiach, Cusco, OEM (apex rear bar) > whiteline anything.
