Hey guys. First post here so bear with me.
I recently picked up a 2015 Off-Road Tacoma from a dealer in Canada.
One weekend up at the cabin, I had the heat going full blast defrosting the window while I was de-icing the windows on the outside of the vehicle. All doors were closed. When I was scraping the drivers window, I noticed the ice flakes blasting up into the air from what appeared to be a loose moulding. It was then I discovered that air was leaking from the cab. I checked the passenger window in the same spot, and it was also leaking air.
I've attached a picture (I hope) of where the problem area is.
I took it into the dealer to have it fixed. The service manager said he had never seen this issue before. After a long process of having the part not ordered, and silicone all over the inside of my vehicle after the job was complete, I got my truck back. The new trim didn't fix a thing. We started to compare to other vehicles in the lot and all of the Tacoma's were leaking air in the same spot. So I lost all my factory seals on the trims inside the doors because of this.
I took it to another Toyota dealer to have it looked at after the first service He was in shock as well, and the Service Manager there said that if the other trucks had it, it was designed that way. He had never seen this issue before. I asked about water entering the door cavity and water sitting inside the door, and salt from road salting entering the door cavity and rusting away the inside. He said that even if water got in with the salt, there wouldn't be a problem for the paint would protect the vehicle.
To me, this shouldn't leak in this spot. When driving, this is the area the water pools to. I notice an excess moisture on the inside of my window as well every morning. I keep the inside of my vehicle dry and clean.
I am looking for some advice. Am I over reacting? Is this a problem that I should just forget about?
