Radio not working after battery install
5 reading
9.8K views 8 replies 8 participants last post by  Tazio Nuvolari
I had to install a new battery and afterword my radio and navigation system did not work. This seems to be a common problem. I searched a number of sites trying to find how to restore it. Several sites suggested disconnecting the battery and leave it for awhile but that didn't work for me. I fortunately found this video on Youtube that restored my radio/navigation perfectly.
I'm sharing in case anyone else encounters this problem.
FWIW; From the service manual:
"After the ignition switch is turned off, the radio and display receiver assembly or the radio receiver assembly records various types of memory and settings. As a result, after turning the ignition switch off, make sure to wait at least 120 seconds before disconnecting the cable from the negative (-) auxiliary battery terminal."
Thank you for posting this, It worked!! Dealer installed a new battery on my 2021 Highlander and the radio would not would not come on.
#9 ·
I don't think so. Whether or not the touchscreen gets some problems or not after a battery replacement seems like it's random. Some 5th gen RAVs may have very minor troubles and some may have none. Any such touchscreen problems are always easy to fix by either the Reverse Reboot procedure or by checking and re-doing the various vehicle settings which might have gotten erased.
