Rear wheel at passenger side moves. Need Help!!
1 reading
14K views 27 replies 9 participants last post by  osheen
Hi All My 97 camry got a problem on the rear passenger side. When I jack the car up, I can hear the "click" if I try to shack the tire side by side. Up and down is ok. I thought it was the wheel hub bearing and just replaced. It still make that noise. So I remove the tire and try to shack the whole part and the noise seem coming from the struts. I talk to my auto guy and he said if the struts is worn, I should be able to make the noise by hold the tire up and down not left/right side.... Then what could it be?
I wouldn't suggest that. You would need a pretty big hydraulic press to press the bushing in and out and I'm not sure if the bushings are even available seperately. I think you are just going to have to bite the bullet on this repair and buy the part OEM. Replace it and then redo the alignment. If you find this part or the bushings in the aftermarket, post back here so eveyone can benefit by your find.
Mike
#9 ·
I don't think that will work. I replaced this exact part on my Cam last week for the same reason. With the arm removed from the vehicle, it felt like there was a ball joint on the outer end. It's definitely not just a simple rubber bushing. I couldn't see any way to get in there and tighten it up. BTW, I purchased the new part from toyotapartsales.com; the "w/ ABS" version was ~$136 including shipping.
From ToyoDIY.com
http://www.toyodiy.com/parts/p_U_2001_TOYOTA_CAMRY_SXV20L-AEPNKA_4804.html?hl=48730F
Part number is 48730-33050
From ToyotaPartSales.com
Item Number MSRP Core Price Price
4873033050 $159.79 $0.00 $124.88
Rear suspension - Lower control arm - Rear arm
Rear arm, camry, right, w/o solara, japan built - avalon, camry, corolla 1995-02 1997 - 2001
Shipping should be about $18.73...
Total is $143.61... ;)
#11 ·
Bad rear Control Rod
This has been a really informative thread. I'm pretty sure I have the same problem on my passenger side rear wheel (1995 Camry LE Sedan). It's been going on for 2 years and I had it looked at. Thankfully i didn't trust the Monroe guys to replace my four struts and mounts for 800. One other mechanic said it was the bushings, and that he just greased them up for me for free. Basically, he said don't stress out over it. It has gotten a bit worse though. Rattling sounds on certain bumps.
How hard is this control rod to replace?? It looks like I don't even have to take the tire off and just have to undo two bolts. I can do my own oil changes, change a tire, and can put together ikea furniture. Should I try this on my own and then take it in for an alignment when I'm done?
I can't find any step-by-step info on the web. Any links?
Thanks for the info.
"Should I try this on my own and then take it in for an alignment when I'm done?"
You can give it a try. It is only those two bolts but they can be a PITA. I suggest soaking them in some good penetrating oil like PB Blaster (not WD-40) for a couple of days before trying this. Spary them each day and then drive the car for those days so the vibrations of driving will help the penetrating oil work itself in to the threads. Then try to loosen those bolts.
Mike
#13 ·
pc65 - Yeah, it's a pretty simple job. Like you said, There's no need to remove the tire, and get it aligned when you're done. I did mine with the rear wheels up on ramps. To get the alignment reasonably close (so I could drive to the alignment shop without tearing up my tires), I measured the center-to-center bolt-hole distance on the old part with a tape measure and set the new one to match it before installing it. And like Mike said, soak those bolts with some penetrating oil long before you tackle the job. Time is your friend.
The fasteners on mine were REALLY tight. I had to use a 1/2" breaker bar PLUS a 3 foot long piece of pipe to get enough leverage to crack 'em loose.
#16 ·
Called all over the place and some of them said it's dealer only parts.
Rockauto.com got those and seems cheaper than the dealership. My local (canada) dealership ask for $210!!!
1997 TOYOTA CAMRY LE 2.2L 2164cc L4 MFI (G) [5SFE]
Suspension : Control Arm
BECK/ARNLEY Part # 1015472 {(Only 2 Remaining)}
REAR RIGHT LOWER; Japan Built
$81.79 $0.00 $81.79
The repair manual said the 181N.m(134ft.lbf ) for those nuts... Give yourself a image how tight it is... The front tire shows 103N.m(76ft.lbf)
I haven't get my parts yet. But I will start to put some oil on that nuts first.
Thanks everyone, I will keep update.
#20 ·
Will stop at CT tonight and grab one....
I called around finally there is a shop can get it for 75 plus tax. He seems know that problem pretty well. But I got my friend who open a car gerage can get the thing for $100 all in. I go for my friend.
Auto Parts International
796 Burlington Street East
Hamilton, ON L8L 4K3
(905) 547-1111‎
#21 ·
okok.... about 2 hours... Thanks everybody... Mike and Whip, you guys are great.
done.
couple tips... PB Blaster is must... Put it on, wait 10 mins, put it again, 10 mins.. with 2ft bar, Nuts get off easily.
The center nuts could be a problem, gas tank is just 5mm away from the bot. I can't put the socket in, went to CT bought a set of offset boxend wrench... not on sale... cost me $59... Never get enough tool!!!
You need to lose the left center side nuts as well, since there is a steel piece in the middle hold both nuts. You not be able to move it since the nuts is very tight...
I try to measure the length of the old one and set it on the new one, not sure if it works or not. Try to save that 70...
Q: how do you know you need to do the alignment???
#22 ·
No way to know for sure without getting it checked. FWIW, the toe in/out on mine was out of spec by 0.8 degrees. Not enough to matter for the 20 mile trip to the alignment shop, but I'd guess it would've made itself known eventually by wearing on one side of tire.
#24 ·
Glad the hard job is done. I would get the alignment done. By just keeping an eye on it you will eventually notice rear tire wear. By then you will need to replace BOTH rear tires and then still get the alignment done. Tires should be replaced in pairs on the same set of axles to keep tread wear even. If the tires have different wear patterns and amount of tread on them (on the same set of axles) you will get some unusual handling characteristics. Get it done now before you wear that tire unevenly.
Mike
#28 ·
Energy Suspension makes a bushing kit for the control arms. But it doesn't include the bushings for the trailing arm that runs front to back. Anyone ever replace those bushings or arm? Mine is sloppy at the front bushing of the trailing arm. I'd hate to have to buy a new arm just for the bushing. Being a machinist, I think I will make my own bushing for it since I can't seem to find an aftermarket one for it.......
