If you guys can shed any light on this... I've "fixed" the problem a few times but it keeps cropping back up on my 1997 with AT. Here's a quick rundown:
So now I'm at the end of things to try and money to spend. I can get the shop to replace the ECU since it's under warranty but is there something else that could cause the problem?
- Original issue, would not go into overdrive last winter. Had the entire unit rebuilt at a cost of $2800, was working fine for about 6 months but I don't drive this truck a lot, not my daily driver. Overdrive again stopped engaging.
- The shop inspected it, diagnosed as a faulty ECU. Replaced with a reman unit at a cost of $400. That worked for about a month again on light duty.
- Since then, I've replaced the Throttle Position Sensor (new part) - no change. (BTW, the 1997 TPS does not adjust, it's plug and play)
- Replaced Transmission Fluid Sensor (used good unit) - no change.
- I replaced the thermostat with a new OEM part, overdrive DID work for a short time, but then stopped engaging again.
